Still Supported
revsmitty
Still Supported
Post by revsmitty »
Is this supported for the latest 10.5 patch 5?
I tried installing this today and we are not seeing the extra tab.
-Thanks
starbucksgold
Re: Still Supported
Post by starbucksgold »
revsmitty,
Mapped Drives is still supported in 10.5 through SP7. Please be sure to check that the Plugin is enabled in Plugin Manager and then Reload DBAgent Plugins, close CC, and re-open. This should get your issue resolved.
FYI - this is currently working on LT 11 SP2 as well.
Thanks.
Jeff (Starbucksgold)
revsmitty
Re: Still Supported
Post by revsmitty »
Followed these steps again and I still do not see the tab....
starbucksgold
Re: Still Supported
When you have a few minutes can we do a remote connection so I can assist?
You can ping me at 850-270-3205. Thanks.
Jeff
revsmitty
Re: Still Supported
Post by revsmitty »
Just saw this. Sent a PM.
Re: Still Supported
Did you guys get this resolved?
Was it a block on the DLL file or something else?
starbucksgold
Re: Still Supported
Shannon,
We are going to try and do a remote session today. I'll let you know. Thanks.
Jeff
Re: Still Supported
starbucksgold wrote:Shannon,
Jeff
Thanks Jeff! :ugeek:
jbeaver
Re: Still Supported
Post by jbeaver »
I would also be interested in the solution for this. We are not seeing the mapped drives tab either.
Are you on LT11? if so try holding the Shift key while opening a computer console. this will open console in old view. Is Tab there?
jbeaver
Re: Still Supported
Post by jbeaver »
We are not on 11, we are still on 10.5 patch 7. And holding shift does nothing. Please contact me directly.
Return to “Map Drives Plugin”
